Hi,
I'm newish to Zorin running 16.2, I need help in removing files from a usb drive for reuse.
thanks
This should be easy, you plug it and you remove all files manually or format the USB drive with Disks. If you use Disks, ensure that you select that USB drive to format and not your computer drive
