How to replace login screen with lock screen
When I first turn on my computer I am greeted with the login screen which imo ugly, once I sign in and get to my desktop I can click the lock icon to access the lock screen which looks great, so I'm wondering if there's a way to see the lock screen when I open my computer rather than the login screen.
What you are specifically asking - cannot be done. The Lockscreen is handled by Gnome Shell and the Login Window is GDM - they are separate and must be, since GDM manages the First Level Authentication.
Instead, why not theme your GDM login window to something you find less ugly?
You can use the app gdm-settings to customize the login screen. Follow the instructions for ubuntu 24.04 to install it.
Thanks this worked well, I didn't want to do much anyways, just changed the wallpaper and text color on, while I couldn't do what I originally wanted my login screen looks much better now
