Glad to hear that! It is really the easier method to go back to an older kernel and wait a bit until the problems are solved with kernel 6.17.
Makes sense, but getting there was a mystery until you outlined the steps. Thanks again!
Moved from "Tutorials" to "General Help" and marked post #19 as Solution.
Another case of 6.17 kernel update regression, fixed by roll-back to 6.14.
Arrgh. This thread is messy and probably needs to be split. I lost sight that OP fixed the problem and moved to Tutorial. Then @trbshtr4 joined the thread which was fixed by kernel roll-back. I will revert the changes I made.
