Greetings my fellow humans, so I've been struck by problem which i don't know how it happens. The settings won't open no matter which settings it was. The 'settings' problem even bother with almost everything related to or included in the settings, like i can't turn on/off bluetooth and switching into TV or projector. I use Zorin 15
Here's the solutions i found:
sudo apt update && sudo apt upgrade -y
(let it run) andsudo apt autoremove
sudo apt-get remove unity-control-center
sudo apt autoremove
sudo apt-get install unity-control-center -
dconf reset -f /org/gnome/control-center/
My problem was solved using the last solution, i hope this may help.
Cheers
