Hello. How do I set default sound output and input? It keep putting back to "default" that I am not using the sound when I'm booting the computer
This is an ongoing problem on Linux, and there is no clear solution to prevent it. What I do have for you however, is a working solution to allow you to keep changing it back after every reboot.
Please go to Gnome-Extensions website. Click install browser integration. Once that is done, click this link...
https://extensions.gnome.org/extension/906/sound-output-device-chooser/
Click the toggle button on the right to install the extension. A popup will come up that asks you to confirm, by all means, please confirm.
Now that your extension is installed, it will be located at the right of your taskbar.
I have mine set to HDMI output because that is what I am using. I know this isn't a perfectly solution, but its enough to keep things going smoothly. For the record, this is what I have been doing for years now, works for me. Hope this helps!
StarTreker
Your Tech Support Guru
Yeah that will do. Thanks!
