I don't always use bluetooth devices with my laptop, so I would like to save some battery and only turn in on when I need to.
I followed this tutorial to disable the bluetooth service at startup. Unfortunately, this means I would have to type the command in the terminal, log out and back in again for it to activate. I can't simply turn on bluetooth via task bar or settings anymore.
Does anyone know if it is possible to change the status of the bluetooth connection to OFF instead of ON at system start?
