How to turn off both Airplane mode & Bluetooth?
When I turn off Bluetooth, Airplane mode gets turned on, but when I turn off Airplane mode, Bluetooth gets back on.
Is there a way to turn and keep both off?
This may help, not sure.
This solution is for HP devices, but will this work on a Dell XPS 15 device?
How exactly will that help turn off both Bluetooth and Airplane mode at the same time?
Because I'm trying to keep my taskbar to have only the battery, volume level, clock time & date and network status on display.
When I boot into Zorin OS the Airplane mode icon is always visible, how do I remove it from the taskbar?
I tried right clicking the taskbar but I can't see the customize option anywhere?
There was a poster in that thread who had a different brand and it worked for them.
Please send me a link to that post/thread.
Can I also have the network status such as the Wifi connection icon displayed on my taskbar?
I got the latest disk image for Zorin 16.2 from the official Zorin site, I flashed it via Balena Etcher on a Sandisk USB stick.
Another thing is whenever I turn off Airplane mode to use Wifi or Ethernet - Bluetooth automatically turns on too, how can I use Wifi without having Bluetooth turning itself on?
But does this really help on a Dell XPS 15 Device rather than a HP one?
Or should I just simply give it a try regardless?
You could give it a try, but don't know whether it would work or not.
I'm looking for a way to turn off both airplane mode and bluetooth while I'm using wifi - without having to reboot and restart my computer...
When I turn off airplane mode, bluetooth automatically turns on - but when I turn off bluetooth, airplane mode turns on suddenly...
I already tried right clicking on taskbar but no customize or properties option appears?
Turning off airplane mode while bluetooth automatically turns on and is visible.
