Hello guys,
I need to install/run SetupVPN on ZorinOS, but since I am not an advanced user, please could you give me a hint.
Double click the file named setupvpn.
You may need to right click it, choose properties, then ensure it has Executable permission.
I did that already, but nothing happened. I guessed maybe it's something like AppImage, I clicked on it, but it didn't tun
I downloaded it to test it to be sure before replying.
Double clicking it worked. But it took a very long time to initialize.
So everything is OK, but the application has an unknown problem.
Thanks.
Unknown problem?
Yep, doesn't run on my PC, I wait for an hour. I don't know why
It is supposed to connect to its servers first. I wonder if it is failing to connect.
I don't know, maybe ... anyway I am okay with its browser's plugin
