I noticed that Remmina supports Windows RDP - I have tried connecting to works network and failed - guess I would need to have IT give me the settings. If I want to get to data on the internal shared drive I have to use Windows 7 VM and Edge to connect. If it needs IT input they might say “Computer says no!”
Remmina has nothing to do with connecting from windows to zorin
Hi, I guess I knew that. Just pointing out that it supports Windows RDP Protocol so it should be possible, (in theory) to login using Windows RDP with a Remmina connection? It’s (moret than) a bit above my technical expertise!
You can easily XRDP to Zorin OS by using tools like logmein, R-HUB remote support servers etc. These are easy to use and work well on all platforms.
