Hi bro
I am just installed truetype fonts in zorin for my work and I want know to how to uninstall truetype fonts
Hi bro
You can find fonts located in either
/usr/share/fonts
or locally in your home folder in
~/.fonts
Navigate into whichever of those folders contain the font you no longer want and move the .ttf file you want to remove to the trash or delete it outright. That’s all you need to do to uninstall a font.
You can alternatively do so from terminal with the ‘rm’ command followed by the Path To The Font in Question.
