Greetings,
You may as me have the "old" game World of Goo installed and want to play it. But the resolution is low and there's no sound in it. There's a fix for that. Note: This is the .deb version of World of Goo from Humble Bundle.
Resolution Fix
Open the terminal and copy/paste;
cp -r /opt/WorldOfGoo/properties/config.txt ~/.WorldOfGoo
nano ~/.WorldOfGoo/config.txt
Under Graphic Display change
<param name="screen_width" value="800" />
<param name="screen_height" value="600" />
to your prefered resolution.
ctrl +o = Save
ctrl+x = Exit
That's it!
Fix Sound
alacarte
Find World of Goo under the Games category. Click it and click Properties.
In Command box change the line to;
padsp /opt/WorldOfGoo/WorldOfGoo
There you go!
Enjoy!
