HP Deskjet D2460
Hello.
How do I install the drivers for a HP Deskjet D2460 printer in a Zorin OS 15.3 lite ?
Thank you in advance for the support you may provide.
Best regards,
Jean-Pierre.
Let's begin with
sudo apt install hplip hplip-gui hplip-data hplip-doc hpijs-ppds libsane-hpaio printer-driver-hpcups printer-driver-hpijs
then in the same terminal window, run
hp-setup
Hello Aravisian.
It work perfectly.
Thank you for the excellent support.
Best regards,
Jean-Pierre.
