HP Elitebook 840 G10 fans not available in Zorin 17
Hello all,
I have been noticing my new Elitebook 840 G10 fans are not active in Zorin 17. "Hardware Sensor Indicator" app shows temps well over the 170F temps constantly.
"FanControl" states "there are no pwm capable fans in your system"
The fans are not dirty, this is a new laptop out of the box.
They work in Windows.
I'm sort of at a loss on how to get the fans working in Zorin OS.
Does anyone have any experience with this?
Thanks
Welcome to the forum!
So I did a quick look and this seems like a fairly new laptop. Sometimes things like this would require newer intel-microcode in order to function properly. However, if you install lm-sensors and see if anything is noticed that way, it might be another check.
If it's a situation where newer microcode is required, sometimes if you search in Synaptic for Intel-microcode, you may find a newer package available. You could also check "Additional Drivers", but I doubt that would show anything.
You may also try the following grub parameters:
acpi_osi= acpi_enforce_resources=lax
Ensure you have done sources updates and upgrades, first.
I recommend performing all CLI actions using the Advanced options > Recovery Menu to conserve resources and avoid overheating while you run the commands.
This is the result of running:
Hit:1 hxxps://ocean.surfshark.com/debian stretch InRelease
Hit:2 Index of /ubuntu jammy InRelease
Hit:3 Index of /ubuntu jammy-updates InRelease
Hit:4 Index of /ubuntu jammy-backports InRelease
Hit:5 hxxps://packages.mozilla.org/apt mozilla InRelease
Hit:6 Index of /ubuntu jammy-security InRelease
Hit:7 hxxps://packages.zorinos.com/stable jammy InRelease
Hit:8 hxxps://ppa.launchpadcontent.net/zorinos/apps/ubuntu jammy InRelease
Hit:9 hxxps://packages.zorinos.com/patches jammy InRelease
Hit:10 hxxps://ppa.launchpadcontent.net/zorinos/drivers/ubuntu jammy InRelease
Hit:11 hxxps://packages.zorinos.com/apps jammy InRelease
Hit:12 hxxps://ppa.launchpadcontent.net/zorinos/patches/ubuntu jammy InRelease
Hit:13 hxxps://packages.zorinos.com/drivers jammy InRelease
Hit:14 hxxps://ppa.launchpadcontent.net/zorinos/stable/ubuntu jammy InRelease
Hit:15 hxxps://packages.zorinos.com/premium jammy InRelease
Reading package lists... Done
All packages are up to date.
Calculating upgrade... Done
libgsoap-2.8.117 liblzf1 nvidia-firmware-550-550.90.07
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Also is this a dual boot setup, or is this running solo on a drive, or is it in a virtual machine? I would be curious if you ran (off a live USB) a newer OS (such as an Arch based distro) that contains newer kernel and microcode that might solve this issue.
Hi again,
This is Zorin OS 17 installed to the bare metal on this laptop. Cleaned the partition and installed from a Zorin bootable USB.
