So, i've got this laptop from a friend.
it was running perfectly on Windows 7 but since it is a relatively old system, i figured it was better to install Zorin OS 15.3.
The installation process went smoothly except for one part. it wouldn't connect to any wifi network even though it was recognizing them. Since it was the installation process, i hooked an ethernet cable and it worked so the installation process could proceed.
At the desktop, the same thing happens - it is able to recognize all nearby networks, but it won't connect to any of them. I've even tried creating a wifi hotspot with an android phone, but no success at all. When i input the password, it tries to connect for a few seconds and then give up, outputting no errors.
I've read other posts here, but it really didn't helped much because the fixes were pretty hardware specific.
I saw people asking for the output from these command lines:
lspci -nn | grep 0280
lsusb
sudo lshw -c network
sudo rfkill list all
that was the result:
pedro@pedroPC:~$ lspci -nn | grep 0280
08:00.0 Network controller [0280]: Ralink corp. RT3090 Wireless 802.11n 1T/1R PCIe [1814:3090]
pedro@pedroPC:~$ lsusb
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 007 Device 003: ID 148f:1000 Ralink Technology, Corp. Motorola BC4 Bluetooth 3.0+HS Adapter
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 002: ID 10f1:1a16 Importek
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
pedro@pedroPC:~$ sudo lshw -c network
*-network
product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
physical id: 0
bus info: pci@0000:02:00.0
logical name: ens4
version: 03
serial: d4:85:64:ce:aa:8a
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix vpd bus_master cap_list rom ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8169 firmware=rtl_nic/rtl8168d-2.fw latency=0 link=no multicast=yes port=MII
resources: irq:16 ioport:2000(size=256) memory:d0004000-d0004fff memory:d0000000-d0003fff memory:d1100000-d111ffff
*-network
product: RT3090 Wireless 802.11n 1T/1R PCIe
vendor: Ralink corp.
physical id: 0
bus info: pci@0000:08:00.0
logical name: wls5
version: 00
serial: 70:f3:95:6d:0c:5c
width: 32 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
configuration: broadcast=yes driver=rt2800pci driverversion=5.4.0-81-generic firmware=0.40 latency=0 link=no multicast=yes wireless=IEEE 802.11
resources: irq:17 memory:d1000000-d100ffff
pedro@pedroPC:~$ sudo rfkill list all
1: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
2: hp-bluetooth: Bluetooth
Soft blocked: no
Hard blocked: no
3: hp-wifi: Wireless LAN
Soft blocked: no
Hard blocked: no
4: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
