Find the remaining kernel, then sudo apt remove... any above 5.8
dpkg --list | grep linux-headers
Same as above
dpkg --list | grep linux-modules
Same as above... Once you have cleaned out all remaining pieces of 5.11, please reboot and test.
(I guess you could also do the same in Synaptic - by searching for 5.11.0-38, selecting any as "remove completely" and then clicking apply.
It just now occurred to me. I use the terminal for most things.)
Well this is bizarre; after listing and removing all those components Terminal now reports that I'm running the 5.8.0-63 version on boot up but the sleep > wake issue has returned.
I tested it numerous times using both the power button (set to sleep) and closing the lid + walking away and it worked when I had to select which kernel to run
If you thought that was bad; I just put 5.11.0-38 back in and low and behold the sleep function is working correctly again when you select to boot from 5.8.0-63 on grub
It acts as though there is a cross dependency; which makes no sense to me lol
Let's set grub to boot from the last Kernel you selected. Boot into 5.8, then open a terminal and
sudo nano /etc/default/grub
Change GRUB_DEFAULT=0 to GRUB_DEFAULT=saved
Then hit enter to make a new line and add this line into that space: GRUB_SAVEDEFAULT=true
Hit ctrl+x to exit, then the y key to say yes to save, then the enter key to save as current configuration.
The terminal will revert to normal- run sudo update-grub
Okay I've got another log of 'that's weird' to add to the pile of 'why the heck is that happening'
I made the changes to grub and updated it. Rebooted the machine and selected the 5.8 kernel under advanced. Verified it was running 5.8. Tested the Sleep > Wake (multiple times) and everything was fine.
Powered off and Powered on the device. Let the timer run out so that the system would automatically boot the default selection in GRUB. Verified that the version running was 5.8. Tested Sleep > Wake. 1st time it worked. 2nd time it woke up then immediately went back to sleep so I woke it again. 4th time it went to sleep and never woke up.
Powered off and manually selected 5.8. Retested Sleep > Wake multiple times. No problem.
Well the good news is it also seems to work if, on bootup, you leave the selection (which is already on Advanced) alone and just keep pressing enter (5.8 gets selected automatically). So as a workaround it isn't terrible but I do hope this gets addressed.
Since 5.8 is being selected now should I leave those synaptic files locked? Or is it better to let the system update things and just let Grub select the 5.8 on bootup?
Spoke too soon again!
LOL! So it also seems there is a difference between closing the lid and pushing the button (set to sleep). If I push the button after 1-2 more sleep > wake tests everything locks up and the system stops waking.
Well we are onto something. What I'm finding is, having turned off the option in settings to sleep from power button, that closing and reopening the lid is consistently working.
I don't know why closing the lid would be different from pressing the 'sleep' button but this is at least a viable option for the time being.
If you have any scenarios you want me to try specifically please let me know and I'll test them out.
Tried this after the computer locked up again (more on that later) and the keyboard/mouse do not register at all. Nothing comes up with that keyboard combination alt + f2
So I had to switch back to the windows installation on the laptop today to open a file for the girlfriend. After switching back to the 5.8 kernel the machine started locking up again.
I finally got it back to the point where sleep mode works by doing the following:
logging in with kernel 5.11
power off
logging in with kernel 5.8
power off
Pressing enter repeatedly on the selected menu items to boot to 5.8
any other combination or switching to windows and the computer would lock up at sleep.
Very bizarre behaviour. Wondering if there is another kernel I should try?
