Start up sound disappeared. Is there any way to restore it?
I tried from startup applications and from stacer, nothing, it doesn’t work anymore. Is it possible from a terminal?
Thanks, Maurizio
Thanks, Maurizio
Latest version of Zorin OS...no startup and shutdown sounds? may or may not help
I don’t have my computer at the moment, it’s under repair. When they return it I try to do something, but not sure if I can … still useful.
See my solution that works:
Thanks swarfendor437, but I don’t have a computer right now … When they give it back, try what you suggest. hello Maurizio
I think there is a way to reinstall it. I found this, but it might be a bit outdated. ![]()
Hola, ir a programas de inicio
Zorin 15 is already End Of Life.
As this thread is quite old and no longer relevant, I'm closing it. If you have any issues in this regard please start a new thread detailing the problem, any troubleshooting done, hardware information, Zorin OS version, etc.
