I Installed GE-Proton10-34 from Protonplus and not working on vtube studio but reinstalled using protonup-qt is working-why?
Hello :smiley:
I have jsut a question: why installing GE-proton10-34 from prptonplus-Vtube studio not workib but when unsitall and install ge-proton10-34 from protonup-qt - is working amazing?
If the question is very difficult and I am worried about a question that contains a hidden camera, I will answer
ProtonPlus-Vtube puts GE-Proton files in a folder that Steam doesn't recognize in Zorin (mostly because of the Flatpak vs DEB path difference), while ProtonUp-Qt automatically detects the correct path for your copy of Steam and places the files in ~/.steam/root/compatibilitytools.d/ where everything works correctly.
Conclusion: Keep using ProtonUp-Qt because it is designed to handle variations of distributions like Zorin.
I understood :smiley:
Protonplis install in /home/myacoitn/.setam/debian-instalation/compabilitytools.d like protonup-qt but - not working xD
Thank you for anwser :smiley:
I'm just doing my duty; :detective: if you have a question, I'm not here.
That's actually a pretty common issue!
The main reason is how and where these two tools install the files. ProtonUp-Qt is currently the gold standard and is incredibly reliable with its paths, permissions, and extraction process.
On the other hand, ProtonPlus sometimes has bugs where it:
  1. Extracts the GE-Proton files into the wrong directory (so VTube Studio or Steam can't actually find it).
  2. Fails to set the correct execution permissions on the binaries inside the Proton folder during extraction.
  3. Corrupts the download/extraction slightly without throwing an error.
When you switched to ProtonUp-Qt, it wiped the broken installation and put the exact same GE-Proton version in the correct, clean directory with the right permissions, which is why it instantly worked flawlessly. Stick to ProtonUp-Qt for compatibility tools—it's much more stable!
Please highlight the parts of your posts that were generated using AI (if you have used AI)
Reading the post, it looks like Google Gemini's patterns, to me.
