Hi, I must have done something stupid again, but dont know what, anyway; I have lost my taskbar or my xfce4-panel, and now I wonder, wil using sudo apt install --reinstall xfce4 get it back without bricking my Zorin 16.1 lite?
I am at work right now and so I do not have access to my PC with Zorin at home.
What would any of you suggest please?
Yes, it's ok to try that. It will probably work.
You might try tapping alt+F2, then enter in
xfce4-panel --restart
See if the panel starts and stays.
If not try in terminal
sudo apt install --reinstall xfce4-panel
You are GOLD, it worked, of course
