Hey, I’m new to Linux, and I’ve been trying to install Zorin OS because I'm sick of Windows, but I’m running into some serious problems. Here’s everything that’s gone down so far:
I created a bootable USB using balenaetcher and followed all the steps.
I restarted my system with the USB plugged in and ran the setup till I pressed restart, but instead of booting into Zorin OS, I’m getting this error: "Non-system disk or disk error. Replace and strike any key when ready."
I haven’t disabled Secure Boot yet because I can't find it in my BIOS, but everything else is set up properly in BIOS. I tried to set the USB as the first boot device, but still no luck.
I’ve tried this setup multiple times, and the system doesn’t boot to anything—it just stays stuck on the error.
I even booted into "Try Zorin" mode and made some changes in the terminal and the partitions app, but nothing worked. It still ends up at the same problem.
I’m new to Linux, so maybe I’m missing something, but I really need help here.
Now I'm stuck on that error and the only things I can access is the BIOS menu and if I want to run Zorin os from the USB again
Has anyone had this problem before or knows what I should do to fix it? I’m seriously stuck and would appreciate any advice or solutions.
Thanks in advance!
