I have been using Zorin for about a year now. Started with Zorin Core but liked it so much I bought Zorin 18.1 pro. When an upgrade comes (say 19) will I get that owning Pro or will I have to buy the upgraded version? I don't mind either way. I want to support Zorin and for the very affordable price, I don't mind paying. Just curious how it will play out.
"Will I get access to future updates of Zorin OS Pro?
The purchase will give you access to the current major version of Zorin OS Pro as well as future updates within the version series, such as upcoming point releases. Future major versions — such as Zorin OS 19 Pro — will need to be purchased separately when they will be released in the future. However, you'll be able to upgrade to future major versions at a discount. We will continue to support Zorin OS 18 with software updates until at least June 2029, and you will be able to use Zorin OS 18 Pro for life."
This is the information on the website with frequently asked questions (scroll down to the end of the page).
Hello,
have also Zorin OS 18.1 Pro. To get Upgrade to Zorin OS 19 Pro we will have to pay again for the Pro version. I have heard that this could be reduced if you have the original buying code available.
Hope you enjoy Zorin OS Pro as me.
Yep, I love it! Can't see myself going back to Windows!
Purchasing Pro only counts for the purchased Major Version - in Your Case: You bought Zorin 18 Pro. So, it counts for Zorin 18.
Yes. If you purchased 18 Pro, then you also get point version updates included. i.e. 18.1, 18.2...18.n without any additional cost.
But you are expected to pay again for the next major version e.g. ZorinOS 19 Pro.
