I just installed Zorin. Good looking and great. But I am facing installing Ibus and Ibus Avro.
In fact, Ibus and Ibus Avro are installed (found out as I tried to install those using package manager), but I can not find those anywhere installed. Cannot launch the app, cannot change the engine.
I have tried to use $ Ibus engine ibus-avro. It changes the engine, but the language remains the same.
These are applications that assist the performance of input or other applications. They do not have a GUI application manager that you can open and run.
If ibus-avro is installed, it will enable input use on your keyboard.
As you type, it should allow for phonetic translation:
There are actually GUI in other distros and you select and click to change the settings and preferences and the language of choice.
I could not find it work here.
Terminal$Ibus --- shows the option of Ibus command. Not GUI. Even If I put $Ibus engine Ibus-avro. then the engine changes to Ibus-avro. But nothing happenes. the language does not change when I type.
Also, I can not find the Ibus GUI.
I have used Ibus GUI in Ubuntu, Kubuntu, Mint, MX. Even in Deeping. Gnome, xfce, KDE Plazma, DDE, all worked flawlessly. But Zorin is just sterile abt it. Strange.
This is strange... because I just tested this on Zorin OS 16, installed ibus-avro and opened the preferences from the app menu- as described above.
Can you please remove ibus-avro completely...(I recommend Synaptic package manager for this) and then reinstall it? Perhaps the initial install corrupted.
Thank you very much Aravisian. Apprently there was no problem. Its just that there is no app installed. Rather a setting in the Settings app called "Region and Language" is there. Where is gives you the option to add more language. From there you can add Avro, or for that matter anyother language, if those are installed (usually using Sudo apt install ).
This leads me to an unsolvable problem! I am getting old.
This confuses me...
What does sudo apt install ibus-avro yield in your terminal?
On mine, it offers to install it:
[sudo] password for :
Reading package lists... Done
Building dependency tree
ibus-clutter libclutter-imcontext-0.1-0 libclutter-imcontext-0.1-bin
ibus-avro ibus-clutter libclutter-imcontext-0.1-0
0 upgraded, 4 newly installed, 0 to remove and 0 not upgraded.
Need to get 547 kB of archives.
After this operation, 8,160 kB of additional disk space will be used.
Do you want to continue? [Y/n]
At the end with the help of GPT, I found out that separate engine installation is required as well.
I want to use Gujarati and Hindi Language for that (and For most other language ) we require ibus-m17n sudo apt install ibus-m17n
restarted my pc and now all Indic language are there in language and input setting.
Add language and use Windows + Space to change between language. рдЖрд╢рд╛ рдХрд░рддрд╛ рд╣реБ рдХрд┐ рдпрд╣ рдкреЛрд╕реНрдЯ рдЖрдкрдХреЗ рд▓рд┐рдпреЗ рдорджрджрдЧрд╛рд░ рд╣реЛрдЧрд┐ред
