I'm using the clipboard manager called Clipboard Indicator and I installed it through Gnome Extensions.
I would suggest implementing this extension natively on Zorin OS or creating a solution of your own.
Or go one step further and install Plasma which has a Clipboard Indicator with history by default in the 'system tray'!
I think Zorin should use something like this: Pano - Clipboard Manager - GNOME Shell Extensions
GitHub - oae/gnome-shell-pano: Next-gen Clipboard Manager for Gnome Shell
