I'm not overly experienced with the terminal, and I'd like to know if there's an easy-to-use application to improve the audio quality of my computer. It's a Lenovo Ideapad 5 Pro, and should have decent speakers, but the sound coming out of it is horrible.
It's also very feeble, so I can barely hear anything unless I turn it up to 70-80%. For comparison, my MacBook was already quite loud at 20-30%, and my partner's laptop (HP Essential, a significantly cheaper and less well-built laptop) also has decent speakers at 50-60%.
I tried the generic sound improvement in the Zorin OS docs, but they didn't help much. The sound is fine if I connect my headphones.
Thank you! I tried everything other than blacklisting the driver, no noticeable difference. It might be a bit better in terms of quality, but the overall volume is still very low.
If I try blacklisting it, and it doesn't work, how can I remove it from the blacklist afterwards?
Thanks! Although the audio is still low when compared to my other machines, it works significantly better with that driver blacklisted. I appreciate the help!
