These are the instructions I followed from Claude AI, I am adding it here to tutorials.
Permanent Auto-Mount via fstab (Best for always-on access)
- Install cifs-utils (for SMB):
sudo apt install cifs-utils
- Create a mount point:
sudo mkdir /mnt/nas
- Store credentials securely:
sudo nano /etc/nas-credentials
Add:
username=your_nas_user
password=your_nas_password
Then lock it: sudo chmod 600 /etc/nas-credentials
- Edit fstab:
sudo nano /etc/fstab
Add a line like:
//192.168.x.x/sharename /mnt/nas cifs credentials=/etc/nas-credentials,iocharset=utf8,_netdev 0 0
- Test it:
sudo mount -a
Once each mount point is added, for example /mnt/Music, /mnt/Photo, /mnt/video etc, in nemo address bar enter /mnt to see every mounted folder, drag to the bottom left pane to bookmark them.
