Hello every, wishing you all a great day!
Since my VLC is not working as expected I ditched VLC and started to use celluloid but I noticed I can only increase the volume up to 100% because in VLC we can increase it up to 200%
I was wondering if we can bring this feature in celluloid it would be a great help
If you guys know of any solution please comment
you can increase your entire system volume to 150% actually, check settings > audio > allow raising volume over 100%
I use pavucontrol:
sudo apt install pavucontrol
pavucontrol
I don't want to increase the volume system-wide. Just inside the application (celluloid)
I don't want to do anything in the system. I want that functionality inside the application like editing a config file. As celluloid Is based on MPV right and i guess MPV is highly configurable right?
after I installed Celluloid, I quickly found the option to load an MPV config file within it's settings, so I'd recommend checking that out with your favorite search engine
No worries, I have done it myself
- create a file name mpv.conf
- edit the file with a text editor
- Add these lines to it
volume=100
volume-max=200
- Save the file
- Now create a folder named "mpv" in your desired destination and move the "mpv.conf" file to "mpv" folder
- Open celluloid, preferences, config files, load mpv configuration. then add the previously created "mpv.conf" to it
- Restart celluloid
Boom Mission accomplished
