@Storm , you are pretty good with Inkscape...
I have run into a problem that I never had before.
Installed Inkscape with apt (as I always do).
When using the following script:
for a in $(find `pwd` -type f -name '*.png'); do inkscape -z -f "$a" -l "${a%.png}.svg"; done
It prompts me on each and every file. Which when converting a few hundred images, cannot happen.
If I set in preferences to Not Ask...
All the file Thumbnails are blank.
If it is set to ask, the thumbnails are not blank.
The file contents are fine... But I cannot see the image thumbnails in the folder and that, too, cannot happen.
I tried searching this but... No... No, the internet is quite silent on this.
