Hello. Sticking with Zorin; still learning! I have a Dell M6600 ZOS 17 Core (Biz will update to 17 Pro) and want to install a usb WiFi dongle with a Realtek RTL8139 chipset. Where can I find how to do this? (or is is not a good idea?) Thanks!
The RTL8139 has been around for quite a while. This can mean that it has long term reliable support. So, all this means is that you should be able to plug in the dongle and the system will pick it up and load the correct modules (I believe iwlwifi).
