Well, I am stumped.
And I just did some searching through the web and everything I read of others on same or similar computers had no trouble installing...
Thanks for your help anyway. I don't have any idea how to solve it.
I will continue looking into this, don't let the brevity of my previous reply fool you.
I tried with manjaro plasma desktop, failed at "Create Volatile Files and Directories..."
with the opensource drivers and with proprietary drivers too.
Tried ElementaryOS, I could install it but in the live session it recognized the wifi now after installation not. Tried nmcli radio wifi on
and got failed to set Wi-Fi radio: Object does not exist at path "/org/freedesktop/NetworkManager"
@Sandor9555 your "ASUS BIOS Utility - Advanced Mode" screenshots differ from the "ASUS UEFI BIOS Utility" screenshots I have found doing websearches re switch for fTPM in your case with AMD chipset.
e.g. How To Enable TPM On ASUS BIOS? Step-By-Step Guide , scroll down to " For ASUS AMD Motherboards"
I wonder if BIOS needs an update. What is its version ?
I was able to install elementary OS with safe graphics, and I got these warnings:
W: Possible missing firmware /lib/firmware/amdgpu/ip_discovery.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/vega10_cap.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/sienna_cichlid_cap.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/navi12_cap.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/psp_13_0_10_ta.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/psp_13_0_10_sos.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/aldebaran_cap.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/aldebaran_sjt_mec2.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/aldebaran_sjt_mec.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/gc_11_0_3_imu.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/gc_11_0_3_rlc.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/gc_11_0_3_mec.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/gc_11_0_3_me.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/gc_11_0_3_pfp.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/gc_11_0_0_toc.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/sdma_6_0_3.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/sienna_cichlid_mes1.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/sienna_cichlid_mes.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/navi10_mes.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/gc_11_0_3_mes1.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/gc_11_0_3_mes.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/smu_13_0_10.bin for module amdgpu
update-initramfs: Generating /boot/initrd.img-5.15.0-58-generic
cryptsetup: WARNING: Resume target cryptswap uses a key file
W: Possible missing firmware /lib/firmware/amdgpu/yellow_carp_gpu_info.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/vangogh_gpu_info.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/cyan_skillfish_rlc.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/cyan_skillfish_mec2.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/cyan_skillfish_mec.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/cyan_skillfish_me.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/cyan_skillfish_pfp.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/cyan_skillfish_ce.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/cyan_skillfish_sdma1.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/cyan_skillfish_sdma.bin for module amdgpu
The other things are mostly working like wifi, sound, brightness, etc.
What do you think, is there any chance to install zorin, or now I should be happy with this?
The BIOS version is: 2.20.0049
So I have to update the BIOS.
I never do such before, what do you think, is this tutorial good: Flashing BIOS from Linux - ArchWiki
You can update via BIOS>advanced>EZ update.
Never stupid more so learning, try in the EZ utility flash.
If you need, Heres a link with photos.
It's about 1/2 way down the page, click the link that is titled in BLUE " How to use EZ Flash to update BIOS in UEFI mode" to see the photo's.
^^^^ not a link just an example of how to see the photo's.
From your screenshot, this should be what you are looking for:
Ocka has given you links and advice in his post just above.
I don't have an ASUS machine, so have never experienced their EZ Flash Utility myself.
Thank you, this was the problem, now the zorin core is running
The asus linux tools are not compatible, but everything else is working fine.
