Hey everyone. I tried to install Zorin Lite using manual partitioning. I deleted every partition and made a new table with swap, efi, /, /home, and 2 gb unallocated inside the installer. At the end there's an error about not having enough space 120 gb free.
I tried again many times with different configurations but nothing. O even uses gparted.
I can boot to BIOS normally but boot repair didn't do anything either..
Can you please help me fix this and install Zorin? I tried different distros but it's the same.
Thanks.
Is your BIOS set to AHCI or to RAID?
Did you format the partitions as Fat32, ext4, brtfs?
It also might help if you could post a screenshot of gParted ..... here is a screenshot of mine .... there is a whole lot of information in that one screenshot ....
As @Frog suggested a screenshot will help, sounds as if the efi partition may not be large enough, or the / partition filesystem types play a role as well ext4 and btrfs allocate differently.
