Installation loop?
I wanted to install Zorin OS18 the Education Version on my Surface 9 Pro. It seems to be stuck. The checking of data pre install was succesfull. But after that the Installation seems to be stuck at the Logo. (see attached picture) The SSD is not empty but i want to wipe it in the process. Secure boot is disabled an I wanted to modify the kernel after the first install to the Linux-Surface kernel. How can I safely exit this state? What can I do?
I did a hard reset. The Installationguide startet from the beginning, checked all data again an this time it just worked.
So, all is good now? You don't need Help anymore, right?
No, i don't need help anymore. Thanks for asking! :slight_smile:
