Somehow I messed up and installed a wrong mouse driver in my Zorin OS 16 Pro for my logitech mouse. Now I can't do anything. The mouse works untill I put in my password to open Zorin then freezes. Is there a keyboard shortcut that I can use to access the settings and select the proper driver? Or maybe a way I can do something thru the terminal?
You can access the Terminal by using TTY with the shortcut ctrl+alt+F5
Important Note: You can leave the TTY with ctrl+alt+F7
Remember that ctrl+alt+F7
You can remove the drivers using the relevant terminal commands in TTY.
