Hardware: Dell G5 circa 2020 with internal wifi and dual Intel+NVIDIA GPU.
First: when I set up my WiFi, picked the correct SSID and entered the right password, it rejected my settings the first time. And second time. Froze for a good few minutes, then the next page showed a disabled "download updates" with a sub-message that I don't have WiFi working. So, I don't know if that means it successfully configured my WiFi or not.
So, I continued with the installer. It currently shows "Retrieving file 166 of 277" and it's been, according to the timestamps, around 40 minutes. The last timestamp message is from about five minutes ago:
zorin systemd[1]: sysstat-collect.service: Deactivated successfully
zorin systemd[1]: Finished sysstat-collect.service - system activity accounting tool.
XDG_RUNTIME_DIR (/run/user/1000) is not owned by us (uid 0) but by uid 1000! (This could e.g. happen if you try to connect to a non-root PulseAudio as a root use, over the native protocol. Don't do that.)
So, what now? Reboot? Skip?
EDIT: seems like it's still updating (zorin CRON[12345] (root) CMD (command -> debian-sa1 > ... so I'll wait it out I guess.
Hello and welcome,
It seem this is not the good moment to install with connection,there are many problems with canonical servers
Try an install without connection, you will update later when servers will be up https://status.canonical.com/#/
One other thing disable secure boot in your BIOS
Secure Boot is already disabled; I used other distros before that required this.
I am not sure if the installer connected to WiFi or not (see my message above). The only options I seem to have now are either a) wait, or b) click the Skip button. What do you recommend?
This worked, thank you. After skipping 4-5 different times in different sections, it completed the installation and booted. I saw some 503 errors related to .ppa files. I'll see if I can get the installer logs.
Maybe there's something to improve here on the UX side -- ping the Ubuntu servers and/or auto-skip if things are super slow, or maybe notify the user and suggest they skip (might be expected in places with poor internet).
after reading logs I don't see something you should be worry about, but if I were you I would ask an AI what I've maybe missed, it will took it few seconds.
I've seen some touchpad problem but I can't judge.
Disks are mounted properly and grub was installed without error.
Anyway, when servers will be online you will update and see.
Separate problem, the updater takes forever to detect, shows "failed to check for updates check your internet" then immediately shows "1.4GB of updates ready."
I tried running apt from terminal but it's locked by packagekitd background service.
I'll use the UI updater and report back if anything else goes wrong (new thread probably makes sense)
