Trying to use Terminal to install 7 zip 26.01. keep getting the message "Unable to locate package 7z2601-linux-x64"
Zorin 18 is based on Ubuntu 24.04 so using the latter in my search criteria in Brave Search engine via Mojeek, brings back Brave A.I. result first with:
" To install the latest official 7-Zip 26.01 on Ubuntu 24.04, you must download the binary directly from the official source, as the Ubuntu 24.04 repository only provides version 23.01 via the 7zip package.
- Download the archive :
wget -O 7z2601-linux-x64.tar.xz https://github.com/ip7z/7zip/releases/download/26.01/7z2601-linux-x64.tar.xz
- Extract and install :
tar -xf 7z2601-linux-x64.tar.xz
sudo install -m 755 7zz /usr/local/bin/7zz
- Verify installation :
7zz --version
This confirms 7-Zip 26.01 . Note that this installs the 7zz binary, which operates independently of the system apt package manager and must be updated manually.
Is there a Reason why You want this newer Version of 7zip? Because Zorin over it - but an older Version.
