Hello, I am new to Linux altogether let alone Zorin OS so I need help in layman's terms. How do I install my HP Deskjet plus 4100 series printer so I can both print and use the rest of the features especially the scanner? Please answer with step by step instructions. Thanks in advance for your help.
@hhcoolb
Which version and flavour of ZorinOS do you have installed. e.g. Z15.3 Core, Lite etc, or maybe Z16 Core Beta?
Assuming you have Z15.3, (Z15 is based on Ubuntu 18.04) so if you websearch "hp deskjet plus 4155 Ubuntu 18.04" see what comes up. I expect it will involve installing HPLIP on Zorin.
I do not have a HP Printer myself so cannot provide you step-by-step instructions.
This item may be of help.
Zorin lite. Thank for the quick reply. Hope the lead helps.
Hi, I have an old HP Laserjet. For HPLIP installation, follow the instruction on this page:
https://developers.hp.com/hp-linux-imaging-and-printing/install/install/index?language=en
(you need to run it in terminal, there is no GUI)
HPLIP can be download here:
https://developers.hp.com/hp-linux-imaging-and-printing/gethplip
(select Ubuntu as OS in drop down list)
