I am using kali linux at a university course in cybersecurity. I want to instal kali linux on my home Zorin machine for practice purposes. I downloaded virtualbox successfully and preceeded to download the virtual machine file at Get Kali | Kali Linux
Upon installing the virtual machine file and running the OS through virtualbox i get not kali linux but the OS pasted into this chat (GRUB).
I havent seen virt manager would it be worthwhile downloading? There is only one extension pack and its compatible with virtual box Version 7.0.12 only
I'm also having issues in virt-manager which uses qemu. I downloaded the qemu image as virt-manager uses .qcow2 format - unzipped the downloaded .qcow2 file and ends up with a Grub command prompt! I would try using a USB image that you can boot from rather than a VM as there appears to be problems with it!
