Installing on a second drive, bootmanager is not showing
Linux / Zorin noob here,
Installed Zorin 18 on a new ssd, to use it alongside windows on my PC. Installation went fine but when i restarted and expected to be thrown into the bootmanager to select rather i want to boot into zorin or windows, it just booted right into Zorin. When i press f12 on restart i can select Zorin or windows.
Maby ive installed the bootloader on the wrong device? On install it didnt ask if i wanted to "installl alsongside Windows", only "Erase disk and and install Zorin OS". Could i fix the problem by just reinstalling Zorin but go into Manual partitioning, select the new drive and under "device for boot loader" select Windows boot manager?
Thx in advance ^^
If Windows and Zorin are both installed in GPT partition scheme and your drive with Windows has a efi partition you could try it with os-prober. First you need to enable it:
Set ubuntu at first position in boot order.
That would be a Way. @Forpli mentioned a different one with os-prober. Only to be sure with a couple Things:
  • Is Fast start-Up in Windows disabled?
  • Is Your BIOS in UEFI or Legacy Mode?
  • What Tool did You use to create the Bootstick?
Thx for the responses ^^
    both yes
    did sudo os-prober with no result so i tryed [ -d /sys/firmware/efi ] && echo UEFI || echo Legacy with the result being UEFI.
    After that lsblk -f gave me NAME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINTS sda ├─sda1 │ ntfs System 65A8A23E76E5A69A ├─sda2 │ ntfs Windows 482C9EEA3F9EB9C5 ├─sda3 │ ntfs 261655C3A0315303 └─sda4 ntfs Recovery 3292758BBB64EB15 sdb ├─sdb1 │ vfat FAT32 B257-A69C 504,8M 1% /boot/efi └─sdb2 ext4 1.0 b1a91f9e-d865-4e8b-8387-0f473c94dc42 373,4G 10% / sdc └─sdc1 ntfs Volume 42E6DC02E6DBF45F sr0.
I think Windows only having an NTFS and no EFI Partition means that windows is indeed in legacy and zorin in UEFI.
balenaEtcher
question is, do i reinstall the OS and partition manually or do i convert windows from Legacy → UEFI with mbr2gpt.exe (solution that poped up in my search)?
There would be another Way - but would be annoying I guess. You install windows again - this Time with GPT Sheme; You could use Rufus to do that. And then install Zorin again.
Not the best Way to handle it, but a Way. Or you try this:
but I don't know this Program. So, You should definetely save Your Data for the Case something gets broken. And prepare Bootsticks.
thx for the fast reply.
Seems to be an official Microsoft-Tool for the migration from legacy to UEFI from what i found.
I mean worst case ill just leave it as it is. I can still access windows just fine though f12.
Guess ill think about my options and post if ill get it resolved though mbr2gpt.exe or close the threat ^^
Well, when they offer that, it should be worth a Try I think. But be prepared for worst Case.
