New Workstation on it's way. I plan on having the host OS as minimal, gnome, browser, email and virt-manager and then just running VM for various use cases.
is there a minimal option version in the installer (assuming yes)
is there any post install 'clean-up' options which can support fully removing default apps e.g Libre Office (use it but would have it in one of the VMs), Wine,
etc..
anything which can help minimize what runs at startup as loading is some times quite slow
Understand there's '15 things you should do after installing Zorin' YT videos however not super keen on that.
The Pro version comes with a minimal installation. However, you might want to trim it for LibreOffice, Cheese, scanner etc. which can be done manually via the software center.
Uninstall snap will improve the loadup speed significant.
Is this true even if no snaps are being used? All of my applications are .deb, flatpak, or AppImage, so snapd shouldn't be doing anything at launch. If it's still slowing down boot, I definitely want to remove it.
