Installing 'tidyverse' package for R/RStudio
With help from this forum, I was able to get R and RStudio working on Zorin 16 Lite. I now need to install the 'tidyverse' package for R, but attempting the install gives this error:
$ sudo R
(R starts up)
> install.packages("tidyverse")
Installing package into ‘/usr/local/lib/R/site-library’
(as ‘lib’ is unspecified)
Warning: dependencies ‘MASS’, ‘lattice’ are not available
also installing the dependencies ‘nlme’, ‘Matrix’, ‘mgcv’, ‘systemfonts’, ‘textshaping’, ‘ggplot2’, ‘ragg’, ‘rvest’, ‘xml2’
trying URL 'https://cloud.r-project.org/src/contrib/nlme_3.1-163.tar.gz'
Content type 'application/x-gzip' length 848981 bytes (829 KB)
downloaded 829 KB
trying URL 'https://cloud.r-project.org/src/contrib/Matrix_1.6-1.1.tar.gz'
Content type 'application/x-gzip' length 2065748 bytes (2.0 MB)
downloaded 2.0 MB
trying URL 'https://cloud.r-project.org/src/contrib/mgcv_1.9-0.tar.gz'
Content type 'application/x-gzip' length 1112050 bytes (1.1 MB)
downloaded 1.1 MB
trying URL 'https://cloud.r-project.org/src/contrib/systemfonts_1.0.5.tar.gz'
Content type 'application/x-gzip' length 80638 bytes (78 KB)
downloaded 78 KB
trying URL 'https://cloud.r-project.org/src/contrib/textshaping_0.3.7.tar.gz'
Content type 'application/x-gzip' length 35100 bytes (34 KB)
downloaded 34 KB
trying URL 'https://cloud.r-project.org/src/contrib/ggplot2_3.4.4.tar.gz'
Content type 'application/x-gzip' length 3159578 bytes (3.0 MB)
downloaded 3.0 MB
trying URL 'https://cloud.r-project.org/src/contrib/ragg_1.2.6.tar.gz'
Content type 'application/x-gzip' length 425391 bytes (415 KB)
downloaded 415 KB
trying URL 'https://cloud.r-project.org/src/contrib/rvest_1.0.3.tar.gz'
Content type 'application/x-gzip' length 94659 bytes (92 KB)
downloaded 92 KB
trying URL 'https://cloud.r-project.org/src/contrib/xml2_1.3.5.tar.gz'
Content type 'application/x-gzip' length 272664 bytes (266 KB)
downloaded 266 KB
trying URL 'https://cloud.r-project.org/src/contrib/tidyverse_2.0.0.tar.gz'
Content type 'application/x-gzip' length 704618 bytes (688 KB)
downloaded 688 KB
ERROR: dependency ‘lattice’ is not available for package ‘nlme’
* removing ‘/usr/local/lib/R/site-library/nlme’
ERROR: dependency ‘lattice’ is not available for package ‘Matrix’
* removing ‘/usr/local/lib/R/site-library/Matrix’
* installing *source* package ‘systemfonts’ ...
** package ‘systemfonts’ successfully unpacked and MD5 sums checked
** using staged installation
Package fontconfig was not found in the pkg-config search path.
Perhaps you should add the directory containing `fontconfig.pc'
to the PKG_CONFIG_PATH environment variable
No package 'fontconfig' found
Package freetype2 was not found in the pkg-config search path.
Perhaps you should add the directory containing `freetype2.pc'
No package 'freetype2' found
Using PKG_CFLAGS=
Using PKG_LIBS=-lfontconfig -lfreetype
--------------------------- [ANTICONF] --------------------------------
Configuration failed to find the fontconfig freetype2 library. Try installing:
 * deb: libfontconfig1-dev (Debian, Ubuntu, etc)
 * rpm: fontconfig-devel (Fedora, EPEL)
 * csw: fontconfig_dev (Solaris)
 * brew: freetype (OSX)
If fontconfig freetype2 is already installed, check that 'pkg-config' is in your
PATH and PKG_CONFIG_PATH contains a fontconfig freetype2.pc file. If pkg-config
is unavailable you can set INCLUDE_DIR and LIB_DIR manually via:
R CMD INSTALL --configure-vars='INCLUDE_DIR=... LIB_DIR=...'
-------------------------- [ERROR MESSAGE] ---------------------------
<stdin>:1:10: fatal error: fontconfig/fontconfig.h: No such file or directory
compilation terminated.
ERROR: configuration failed for package ‘systemfonts’
* removing ‘/usr/local/lib/R/site-library/systemfonts’
* installing *source* package ‘xml2’ ...
** package ‘xml2’ successfully unpacked and MD5 sums checked
Package libxml-2.0 was not found in the pkg-config search path.
Perhaps you should add the directory containing `libxml-2.0.pc'
No package 'libxml-2.0' found
Using PKG_CFLAGS=
Using PKG_LIBS=-lxml2
------------------------- ANTICONF ERROR ---------------------------
Configuration failed because libxml-2.0 was not found. Try installing:
 * deb: libxml2-dev (Debian, Ubuntu, etc)
 * rpm: libxml2-devel (Fedora, CentOS, RHEL)
 * csw: libxml2_dev (Solaris)
If libxml-2.0 is already installed, check that 'pkg-config' is in your
PATH and PKG_CONFIG_PATH contains a libxml-2.0.pc file. If pkg-config
ERROR: configuration failed for package ‘xml2’
* removing ‘/usr/local/lib/R/site-library/xml2’
ERROR: dependencies ‘nlme’, ‘Matrix’ are not available for package ‘mgcv’
* removing ‘/usr/local/lib/R/site-library/mgcv’
ERROR: dependency ‘systemfonts’ is not available for package ‘textshaping’
* removing ‘/usr/local/lib/R/site-library/textshaping’
ERROR: dependency ‘xml2’ is not available for package ‘rvest’
* removing ‘/usr/local/lib/R/site-library/rvest’
ERROR: dependencies ‘MASS’, ‘mgcv’ are not available for package ‘ggplot2’
* removing ‘/usr/local/lib/R/site-library/ggplot2’
ERROR: dependencies ‘systemfonts’, ‘textshaping’ are not available for package ‘ragg’
* removing ‘/usr/local/lib/R/site-library/ragg’
ERROR: dependencies ‘ggplot2’, ‘ragg’, ‘rvest’, ‘xml2’ are not available for package ‘tidyverse’
* removing ‘/usr/local/lib/R/site-library/tidyverse’
The downloaded source packages are in
	‘/tmp/Rtmpr5gSsS/downloaded_packages’
Warning messages:
1: In install.packages("tidyverse") :
  installation of package ‘nlme’ had non-zero exit status
2: In install.packages("tidyverse") :
  installation of package ‘Matrix’ had non-zero exit status
3: In install.packages("tidyverse") :
  installation of package ‘systemfonts’ had non-zero exit status
4: In install.packages("tidyverse") :
  installation of package ‘xml2’ had non-zero exit status
5: In install.packages("tidyverse") :
  installation of package ‘mgcv’ had non-zero exit status
6: In install.packages("tidyverse") :
  installation of package ‘textshaping’ had non-zero exit status
7: In install.packages("tidyverse") :
  installation of package ‘rvest’ had non-zero exit status
8: In install.packages("tidyverse") :
  installation of package ‘ggplot2’ had non-zero exit status
9: In install.packages("tidyverse") :
  installation of package ‘ragg’ had non-zero exit status
10: In install.packages("tidyverse") :
  installation of package ‘tidyverse’ had non-zero exit status
The installation fails because I don't have the 'lattice', 'fontconfig', and 'libxml-2.0' packages. When I try to install these packages manually, R says they aren't available for my current version (3.6.3).
I'm running R 3.6.3 because the up-to-date version of R (4.x) requires a newer version of libc6 that Ubuntu doesn't support (see Installing r-base on Zorin OS (libc6 2.35 needed)). The workaround to this was to install a version of R from the cran2deb repository (cran2deb4ubuntu 4.0 : “cran2deb4ubuntu Build Team” team), which ended up being 3.6.3.
Or at least, that's my understanding? From what I can tell, my options here are to
  1. Update R to the current version. This may or may not be possible, depending on whether I messed up the installation from cran2deb the first time.
  2. Install an older and/or compatible version of the package. Probably also from cran2deb? But I think install.packages should have already been checking the cran2deb repository, and it still failed, so idk really.
Another option would be to install R from Flatpak, which will carry all dependencies with it and provide the latest version. I am aware that this carries cons as well as pros, but given what you are describing, it may be a viable course for you.
Yes, this is reasonable. For your current version lacking certain dependencies, there is another source/ option to always keep in mind.
pkgs.org
I bookmark that source on my browser. When I need to find a dependency, that is nearly the first place I always check for it. The source would be the Base of Zorin OS. For Zorin OS 16, the base is Ubuntu 20.04.
Flatpak: Is R available on flatpak? I did a search for both R and RStudio but nothing relevant came up.
Update R: Is it actually possible to do this? I thought 3.6.3 was the most up-to-date version of R available for me because of the libc6 thing, is that wrong?
Install an older version of the package: So on both pkgs.org and cran2deb, it looks like the only available tidyverse package is some variant of r-cran-tidyverse, which expects me to have R 4.0.0. Does this mean it's possible for me to install R 4.0 from cran2deb? How would I go about doing that?
You are correct.
I would not think so at a glance.
But I am not sure (if we reassemble some package dependencies it might be possible). You said that the highest you can install is 3.6.3
I looked at pckgs.org and am using:
http://archive.ubuntu.com/ubuntu/pool/universe/r/r-cran-tidyverse/r-cran-tidyverse_1.3.0-1_all.deb
Does installing that .deb offer only for R> 4.0?
My comment was based on htis:
But I have not actually checked off-hand that R is indeed available on Flathub.
Doing a net search real fast, I see:
This is actually one of several reasons I actually do not use R or Rstudio. The comments on that page cover similar issues as this thread...
Does install that .deb offer only for R> 4.0?
I'm fairly certain, yes. The cran2deb page mention R 4.0.
Trying to install it gives a bunch of dependency errors:
The following packages have unmet dependencies:
 r-cran-tidyverse : Depends: r-cran-broom but it is not going to be installed
                    Depends: r-cran-dbplyr but it is not going to be installed
                    Depends: r-cran-dplyr but it is not going to be installed
                    Depends: r-cran-dtplyr but it is not going to be installed
                    Depends: r-cran-forcats but it is not going to be installed
                    Depends: r-cran-ggplot2 but it is not going to be installed
                    Depends: r-cran-googledrive but it is not going to be installed
                    Depends: r-cran-googlesheets4 but it is not going to be installed
                    Depends: r-cran-haven but it is not going to be installed
                    Depends: r-cran-hms but it is not going to be installed
                    Depends: r-cran-modelr but it is not going to be installed
                    Depends: r-cran-readr but it is not going to be installed
                    Depends: r-cran-readxl but it is not going to be installed
                    Depends: r-cran-reprex but it is not going to be installed
                    Depends: r-cran-rvest but it is not going to be installed
                    Depends: r-cran-tibble but it is not going to be installed
                    Depends: r-cran-tidyr but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
If I try to download the packages manually, eventually I get to stuff like:
 r-cran-pkgconfig : Depends: r-base-core (>= 3.6.3.20200416-1.2004.0) but 3.6.3-2 is to be installed
                    Depends: r-api-4.0 but it is not installable
It's asking for a slightly more recent version of r-base-core and r-api-4.0, which is weird because apt install r-base-core tells me that r-base-core is already up to date at 3.6.3-2.
(Yeah, I'm not using R out of choice tbh, it's a requirement for a lab I joined)
Perhaps here we can find some help:
https://cran.rstudio.com/bin/linux/ubuntu/
For this line:
sudo add-apt-repository "deb https://cloud.r-project.org/bin/linux/ubuntu $(lsb_release -cs)-cran40/"
You can replace it with:
sudo add-apt-repository "deb https://cloud.r-project.org/bin/linux/ubuntu focal-cran40/"
That did let me update to R 4.3.1, which is progress, but I'm still having some trouble getting tidyverse to install. I'll update you soon
Ok, that solved the problem! tidyverse seems to be working for now.
After updating R from the new repository, I had to:
  1. Reinstall some R packages that were added before the update.
  2. Install tidyverse from cran2deb (Packages in “cran2deb4ubuntu 4.0” : cran2deb4ubuntu 4.0 : “cran2deb4ubuntu Build Team” team). I couldn't get tidyverse to install normally from RStudio, it complained about certain dependencies not being available for my version (as usual).
  3. Running library("tidyverse") then gave me a sort-of error message about package conflicts, but that's apparently nothing to worry about, the package will still work fine (tidyverse - Package Conflicts in R - Stack Overflow).
