Installing Zorin 16 results in Grub Rescue
I am in the middle of installing Z16.2 Core over Z15.3 Core.
On boot I get
error: symbol 'grub_file_filters' not found.
'>grub rescue
Have I missed something when setting up installation. I used Something Else method I've used in the past.
Maybe this should be a new thread.
I bit the bullet and decided to install 16.2 Core instead of using the Upgrader. But have come unstuck as the ubiquity installer is a bit different from Z12 and Z15. Have I missed step re bootloader. I could not see that during installation dialogue.
If you are in the LiveUSB of Zorin OS, are you embedded in the installer or are you able to open a terminal?
I can open a terminal via Live USB.
In terminal, elevate to root to make your life easier:
sudo su
Locate your Zorin OS install partition:
fdisk -l
That is - L
Let's say you were installing on sda1 (modify that to what you see listed from fdisk -l):
mount /dev/sda1 /mnt
mount --bind /dev /mnt/dev
mount --bind /dev/pts /mnt/dev/pts
mount --bind /proc /mnt/proc
mount --bind /sys /mnt/sys
chroot /mnt
grub-install /dev/sda
exit
umount /mnt/dev/pts
umount /mnt/dev
umount /mnt/proc
umount /mnt/sys
umount /mnt
FYI. Note I am dual booting WindowsXP. Also is old laptop, not EFI.
No problem, the above steps remain unchanged. The command of
grub install /dev/sda
handles that portion.
From LIve USB Gparted.
/dev/sda1 is ntfs (i.e. Windows)
/dev/sda2 is extended and includes
sda5 linux-swap
sda6 ext4 which should be / (root)
sda7 ext4 which should be /home
Are your commands above still OK with that?
Be sure to use that instead of the sda1 in my example, then!
When i type
mount /dev/sda# /mnt
where # has been 1 or 6
I get
root@zorin: /home/zorin#
I am puzzled by the term /home in that reply
It should only be 6. You just said that sda1 was your Windows OS partition.
OK. I'm now in Zorin16. Thanks.
Only one user showing, so I guess I have to setup my second user again.
EDIT:
OK I now have Z16.3 Core (via software update from Z16.2) and have set up the basics for two users.
@Aravisian again thankyou for help fixing my Grub issue.
I had the same problem so I will leave this here How to Use Grub Rescue to Fix Linux Boot Failure | phoenixNAP KB . that is actually what helped me restore my grub boot because some odd reason it saved my grub loader to my hdd rather than ssd and got it moved eventually.
