Integrate Clipboard Indicator by default. It is important for successful work
I changed the Thread Category to Feedback because of Your Suggestion/Function Request.
Hi and welcome.
Not probably the best solution but you could always install kde-standard and boot into Plasma DE which has it.
But then it is easier to simply install the Gnome Extension instead a complete different Desktop Environment.
Yeah, kind of radical, changing DE for a clipboard indicator lol
So is there a link for the OP or do they have it?
I would think the User already use it. But suggests here to integrate it by default. There are some Options:
I like the idea of having clipboard history available out of the box, especially since it's one of those small features that can make everyday work much easier.
One thing I'd be careful about, though, is privacy. Clipboard managers can end up storing passwords, verification codes, or other sensitive information without people even realizing it.
Maybe a good compromise would be to include the feature by default but let users decide whether to enable clipboard history during setup. A simple option to pause recording or clear the entire history would be useful too.
I think that would make the feature more approachable for people coming from Windows, without adding another potential privacy concern to a fresh installation.
