Intel 8265 Wi-Fi not detected when booting Zorin OS from external drive (error -110)
Hi everyone,
I’m facing an issue with my internal Wi-Fi not being detected in Zorin OS when booting from an external drive.
System Details
  • Laptop: Dell Precision 7520
  • OS: Zorin OS (based on Ubuntu 24.04 “Noble”)
  • Boot method: Installed and running from external USB drive
  • Wi-Fi chipset: Intel Wireless 8265 / 8275
Problem
The internal Wi-Fi is not detected at all:
  • No wlp... interface appears
  • Wi-Fi networks are not visible
However:
  • The device is visible in lspci
  • A USB Wi-Fi adapter works perfectly
  • Bluetooth (same card) works fine
Observations
  • lspci -k shows the Intel Wi-Fi device
  • Kernel module iwlwifi is available
  • But no “Kernel driver in use” is shown
  • ip a does NOT show any wireless interface
Troubleshooting already done
  • Reinstalled linux-firmware
  • Verified firmware files (iwlwifi-8265-*.ucode )
  • Reloaded driver using modprobe
  • Edited /etc/modprobe.d/iwlwifi.conf with multiple options
  • Disabled power saving
  • Tried disabling 11ac / enabling software crypto
  • Updated initramfs
  • Updated kernel
  • Added GRUB parameters:
    • pcie_aspm=off
    • pci=nomsi
  • Fully rebooted (cold boot)
Device present → module available → no driver bound
Do you have disabled fast startup in Windows if you have a Dualboot with Windows?
You can try to boot with an older kernel (in grub menu select advanced options for Zorin and select an older kernel to boot from).
I'm using external drive to boot my laptop through ZorinOS. it will not work.
hello,
  1. right click on this link and save the link as https://git.kernelfirmware.git/tree/intel/iwlwifi/iwlwifi-8265-36.ucode
    1. Open your terminal and cd into the directory containing the files you just download (iwlwifi-8265-36.ucode)
  2. run sudo cp iwlwifi-8265-36.ucode /lib/firmware
  3. Reboot your computer.
There is an i at the Beginning of iiwlwifi too much.
@saadfamz:
Does Your System run in Wayland or X11? You can check that with the Terminal Command echo $XDG_SESSION_TYPE
Does that mean, You have tried it with installing a newer Kernel?
Could You post the Output of the Commands sudo lshw -C network and rfkill list please?
corrected thank you :wink:
you can also just run
sudo apt install iwlwifi-modules
if the first tip doesn't work
*-network UNCLAIMED
description: Network controller
product: Wireless 8265 / 8275
vendor: Intel Corporation
physical id: 0
bus info: pci@0000:02:00.0
version: 78
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress cap_list
configuration: latency=0
resources: memory:ecb00000-ecb01fff
*-network
product: Ethernet Connection (5) I219-LM
physical id: 1f.6
bus info: pci@0000:00:1f.6
logical name: enp0s31f6
version: 31
serial: a4:4c:c8:43:73:87
capacity: 1Gbit/s
width: 32 bits
clock: 33MHz
capabilities: pm msi bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=e1000e driverversion=6.17.0-20-generic firmware=0.1-3 latency=0 link=no multicast=yes port=twisted pair
resources: irq:16 memory:ecc00000-ecc1ffff
output of rfkill list:
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
1: dell-wifi: Wireless LAN
Soft blocked: no
Hard blocked: no
2: dell-bluetooth: Bluetooth
Soft blocked: no
Hard blocked: no
Please check if the Package backport-iwlwifi-dkms is installed with:
apt list backport-iwlwifi-dkms
Ok I will try and send you the result
