Intel ARC770M not detected with kernel 6.x
Hello,
I have install Zorion Pro version on Intel NUC 12 Enthusiast (Serpent Canyon),
upgraded to kernel 6.4.14 and
I do not have the ARC Video card properly detected.
Does anyone faced the problem? Any clue how to solve it?
thanks
Here is my info:
george@george-NUC12SNKi72:~$ uname -rv
6.4.14-060414-generic #202309020843 SMP PREEMPT_DYNAMIC Sat Sep 2 09:17:40 UTC 2023
george@george-NUC12SNKi72:/lib/firmware$ hwinfo --display
07: PCI 300.0: 0300 VGA compatible controller (VGA)
[Created at pci.386]
Unique ID: svHJ.77hoq_qsqUD
Parent ID: GA8e.mr2N3fBJq5F
SysFS ID: /devices/pci0000:00/0000:00:01.0/0000:01:00.0/0000:02:01.0/0000:03:00.0
SysFS BusID: 0000:03:00.0
Hardware Class: graphics card
Device Name: "dGPU"
Model: "Intel VGA compatible controller"
Vendor: pci 0x8086 "Intel Corporation"
Device: pci 0x5690
SubVendor: pci 0x8086 "Intel Corporation"
SubDevice: pci 0x3026
Revision: 0x08
Driver: "i915"
Driver Modules: "i915"
Memory Range: 0x6b000000-0x6bffffff (rw,non-prefetchable)
Memory Range: 0x6000000000-0x63ffffffff (ro,non-prefetchable)
Memory Range: 0x6c000000-0x6c1fffff (ro,non-prefetchable,disabled)
IRQ: 172 (2637 events)
Module Alias: "pci:v00008086d00005690sv00008086sd00003026bc03sc00i00"
Driver Info #0:
Driver Status: i915 is active
Driver Activation Cmd: "modprobe i915"
Config Status: cfg=new, avail=yes, need=no, active=unknown
Attached to: #31 (PCI bridge)
32: PCI 02.0: 0300 VGA compatible controller (VGA)
Unique ID: _Znp.HMLUX1zIkGC
SysFS ID: /devices/pci0000:00/0000:00:02.0
SysFS BusID: 0000:00:02.0
Device Name: "GPU"
Device: pci 0x46a6
Revision: 0x0c
Driver: "i915"
Memory Range: 0x644c000000-0x644cffffff (rw,non-prefetchable)
Memory Range: 0x4000000000-0x400fffffff (ro,non-prefetchable)
I/O Ports: 0x4000-0x403f (rw)
Memory Range: 0x000c0000-0x000dffff (rw,non-prefetchable,disabled)
IRQ: 171 (204 events)
Module Alias: "pci:v00008086d000046A6sv00008086sd00003026bc03sc00i00"
Driver Info #0:
Primary display adapter: #7
Intel Arc is pretty new. You were correct to advance to the 6.4 kernel to seek driver support, but even so, the xe patch won't be merged into Mainline kernel for another month at the soonest.
You might try (at your own risk - be sure to recall how to use Grub Menu to access Advanced Options for Zorin in case you need to roll back) the Zabbly 6.5 kernel:
It was given support beginning in 6.2... I wouldn't say it was given full support in 6.2. :expressionless:
That article does indeed claim "full" support.
Sadly... It's FOSS also erroneously claimed that Zorin OS 16.3 was based on Ubuntu 22.04. They are pop-tech writers...
Reading the Kernel, you have to sometimes follow the merge requests when examining the Latest Hardware in order to get accurate information.
