flynnh
June 30, 2026, 11:54am
21
Still not claimed. The firmware file download returns:
wget Making sure you're not a bot!
sudo cp iwlwifi-* /lib/firmware/iwlwifi/
--2026-06-30 21:54:08-- Making sure you're not a bot!
Resolving git.kernel.org (git.kernel.org )... 172.236.150.65, 2600:3c15::f03c:95ff:fe40:9857
Connecting to git.kernel.org (git.kernel.org )|172.236.150.65|:443... connected.
HTTP request sent, awaiting response... 404 Not Found
2026-06-30 21:54:08 ERROR 404: Not Found.
2026-06-30 21:54:09 ERROR 404: Not Found.
--2026-06-30 21:54:09-- Making sure you're not a bot!
cp: cannot stat 'iwlwifi-*': No such file or directory
flynnh
June 30, 2026, 11:55am
22
Verifying they copied returns
total 76
drwxr-xr-x 2 root root 4096 Jun 30 21:49 .
drwxr-xr-x 101 root root 69632 Jun 30 21:49 ..
Run these commands instead:
sudo mkdir -p /lib/firmware/iwlwifi
cd /tmp
# Download from GitHub mirror (not blocked)
curl -L "https://raw.githubusercontent.com/OpenIntelWireless/linux-firmware/master/iwlwifi-QuZ-a0-hr-b0-67.ucode" -o iwlwifi-QuZ-a0-hr-b0-67.ucode
# Verify download
ls -lh iwlwifi-QuZ-a0-hr-b0-67.ucode
# Copy to firmware directory
sudo cp iwlwifi-QuZ-a0-hr-b0-*.ucode /lib/firmware/iwlwifi/ 2>/dev/null || true
# Verify
ls -la /lib/firmware/iwlwifi/
flynnh
June 30, 2026, 12:01pm
24
the last command returns
total 80
drwxr-xr-x 2 root root 4096 Jun 30 21:58 .
-rw-r--r-- 1 root root 14 Jun 30 22:01 iwlwifi-QuZ-a0-hr-b0-67.ucode
flynnh
June 30, 2026, 12:04pm
26
*-network:0 UNCLAIMED
description: Network controller
product: Wi-Fi 6 AX201
vendor: Intel Corporation
physical id: 14.3
bus info: pci@0000:00:14.3
version: 20
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix cap_list
configuration: latency=0
resources: iomemory:600-5ff memory:6053194000-6053197fff
*-network:1
product: Ethernet Connection (13) I219-LM
physical id: 1f.6
bus info: pci@0000:00:1f.6
logical name: enp0s31f6
version: 20
serial: 38:14:28:40:5b:9a
capacity: 1Gbit/s
width: 32 bits
clock: 33MHz
capabilities: pm msi bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=e1000e driverversion=6.17.0-35-generic firmware=0.8-4 latency=0 link=no multicast=yes port=twisted pair
resources: irq:145 memory:a2300000-a231ffff
*-network
physical id: f
bus info: usb@3:2
logical name: enxfad416d1baaf
serial: fa:d4:16:d1:ba:af
capabilities: ethernet physical
configuration: autonegotiation=off broadcast=yes driver=cdc_ncm driverversion=6.17.0-35-generic firmware=CDC NCM (NO ZLP) ip=10.135.181.30 link=yes multicast=yes port=twisted pair
Run these commands and paste the output:
sudo dmesg | grep -i "iwl\|firmware" | tail -20
flynnh
June 30, 2026, 12:07pm
28
total 80
and
[ 4.701101] iwlwifi 0000:00:14.3: value [iter 5]: 0x00000000
[ 4.701122] iwlwifi 0000:00:14.3: value [iter 6]: 0x00000000
[ 4.701144] iwlwifi 0000:00:14.3: value [iter 7]: 0x00000000
[ 4.701180] iwlwifi 0000:00:14.3: value [iter 8]: 0x00000000
[ 4.701220] iwlwifi 0000:00:14.3: value [iter 9]: 0x00000000
[ 4.701282] iwlwifi 0000:00:14.3: value [iter 10]: 0x00000000
[ 4.701307] iwlwifi 0000:00:14.3: value [iter 11]: 0x00000000
[ 4.701329] iwlwifi 0000:00:14.3: value [iter 12]: 0x00000000
[ 4.701351] iwlwifi 0000:00:14.3: value [iter 13]: 0x00000000
[ 4.701387] iwlwifi 0000:00:14.3: value [iter 14]: 0x00000000
[ 4.701388] iwlwifi 0000:00:14.3: Host monitor block 0x22 vector 0x0
[ 4.701432] iwlwifi 0000:00:14.3: value [iter 0]: 0x00000000
[ 4.709302] iwlwifi 0000:00:14.3: probe with driver iwlwifi failed with error -110
[ 5.061109] Bluetooth: hci0: Minimum firmware build 1 week 10 2014
[ 5.072691] Bluetooth: hci0: Found device firmware: intel/ibt-19-0-4.sfi
[ 5.072747] Bluetooth: hci0: Firmware Version: 249-27.23
[ 5.579694] i915 0000:00:02.0: [drm] Finished loading DMC firmware i915/tgl_dmc_ver2_12.bin (v2.12)
[ 7.346880] Bluetooth: hci0: Waiting for firmware download to complete
[ 7.347077] Bluetooth: hci0: Firmware loaded in 2221075 usecs
[ 7.365109] Bluetooth: hci0: Firmware revision 0.4 build 249 week 27 2023
try this
sudo rm /lib/firmware/iwlwifi/iwlwifi-QuZ-a0-hr-b0-67.ucode
cd /tmp
sudo apt-get download firmware-iwlwifi=2024-01-01-1 2>/dev/null || apt-get download linux-firmware 2>/dev/null
flynnh
June 30, 2026, 12:23pm
31
apt update still returns everything up to date. the device is still unclaimed. no new updates in settings
Forpli
June 30, 2026, 12:38pm
32
Maybe disabling Intel AMT can help.
Hello everyone, Iām having trouble getting the built-in Wi-Fi to work on my Dell Latitude 5420 after installing Fedora. The card is an Intel AX201. The main symptom is that the card is seen by the system, but no driver will attach to it. The...
Reading time: 6 mins š
Likes: 4 ā¤
https://www.reddit.com/r/Dell/comments/1ssmdx1/dell_latitude_5420/?tl=en
flynnh:
Disabling fast boot (done)
Disabling secure boot (done)
Did You disabled Fast Start-Up in Windows, too?
Also: Does Your Ethernet work? Did You checked the ''Additional Drivers'' Tab in Software & Updates if there is a Driver offered?
In Windows power settings, untick "Fast Start-up", incase Windows is clinging on to that device when Fast Start-Up is enabled.
I can't see that in your DO NOT SUGGEST list
EDIT: I see Ponce-De-Leon has replied the same advice ahead of me. That proves he can type quicker than me
Which Brave A.I. also suggested!
flynnh
July 1, 2026, 8:34am
36
Yes fast startup is also disabled. I believe ethernet works
flynnh
37
Yes Intel AMT was disabled.
flynnh
July 1, 2026, 8:36am
38
Hello everybody, just an update. I truly couldn't get it to work. I tried installing another distro which is based off fedora, but experienced the exact same issue.
This leads me to believe it's either:
A hardware compatibility issues
A BIOS issue
A windows issue (even though I reinstalled it)
I have deleted Linux from my system currently, but if anybody has any more recommendations, I'd be more than happy to give them a try! Thank you for your help.
(Do not mark as solved, I'm still open to recommendations)
flynnh
July 1, 2026, 8:40am
39
I'm reinstalling Zorin now to test a BIOS change relating to Intel AMT. I'll let you know how I go!
Forpli
July 1, 2026, 8:47am
40
In your first post you wrote
flynnh:
DO NOT SUGGEST
Disabling fast boot AND fast startup(done)
Now you write
It is important that fast startup in Windows (power options) is disabled.
