Intel centrino wireless / ethernet problem
Hi there,
Trying to get Zorin OS Core up and running on a moderately old laptop that has an Intel centrino wireless 2230 card.
Initially the WiFi kept asking me for a password but after a bit of digging I disabled the 802.11n protocol.
Now I have the challenge that I can either have the WiFi connected or the ethernet cable plugged in but not both. If I start with an ethernet connection and then remove the cable Zorin won't connect to the WiFi network. This also occurs the other way around. If I start with WiFi enable and working and then plug in the ethernet cable, the cable connection doesn't work.
It might have something to do with my attempts at disabling the 802.11n protocol but before that I had no working WiFi.
Here's the command I used:
sudo tee /etc/modprobe.d/iwlwifi.conf <<< "options iwlwifi 11n_disable=1"
Any assistance in troubleshooting would be appreciated.
Thanks in advance.
