The card worked after updating Zorin OS but only worked for about 10 minutes, not even long enough for me to enter my wifi pw.
Info below:
Using a Tosiba Dynabook T451-35DW - I think Noah made it when he had a day off from the arc.
raisa@raisa-dynabook-T451-35DW:~/Desktop$ rfkill list
0: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
raisa@raisa-dynabook-T451-35DW:~/Desktop$ sudo modprobe -rfv iwlwifi
[sudo] password for raisa:
remove (/sbin/lsmod | grep -o -e ^iwlmvm -e ^iwldvm -e ^iwlwifi | xargs /sbin/rmmod) && /sbin/modprobe -r mac80211
rmmod mac80211
rmmod libarc4
rmmod cfg80211
raisa@raisa-dynabook-T451-35DW:~/Desktop$ sudo modprobe -v iwlwifi
insmod /lib/modules/5.15.0-97-generic/kernel/net/wireless/cfg80211.ko
insmod /lib/modules/5.15.0-97-generic/kernel/drivers/net/wireless/intel/iwlwifi/iwlwifi.ko
raisa@raisa-dynabook-T451-35DW:~/Desktop$ sudo lshw -C network
*-network DISABLED
product: Centrino Wireless-N 1000 [Condor Peak]
vendor: Intel Corporation
physical id: 0
bus info: pci@0000:03:00.0
logical name: wlp3s0
version: 00
serial: 74:e5:0b:17:0b:cc
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
configuration: broadcast=yes driver=iwlwifi driverversion=5.15.0-97-generic firmware=39.31.5.1 build 35138 1000-5.uc latency=0 link=no multicast=yes wireless=IEEE 802.11
resources: irq:32 memory:c0500000-c0501fff
*-network
product: AR8152 v2.0 Fast Ethernet
vendor: Qualcomm Atheros
physical id: 0
bus info: pci@0000:04:00.0
logical name: enp4s0
version: c1
serial: e8:9a:8f:b3:e5:4e
capacity: 100Mbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress vpd bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=atl1c driverversion=5.15.0-97-generic latency=0 link=no multicast=yes port=twisted pair
resources: irq:34 memory:c0400000-c043ffff ioport:2000(size=128)
*-network
physical id: 3
bus info: usb@3:1
logical name: usb0
serial: 26:dd:d7:1e:58:4b
capabilities: ethernet physical
configuration: autonegotiation=off broadcast=yes driver=rndis_host driverversion=5.15.0-97-generic duplex=half firmware=RNDIS device ip=192.168.76.155 link=yes multicast=yes port=twisted pair
raisa@raisa-dynabook-T451-35DW:~/Desktop$ inxi -N
Network:
Device-1: Intel Centrino Wireless-N 1000 [Condor Peak] driver: iwlwifi
Device-2: Qualcomm Atheros AR8152 v2.0 Fast Ethernet driver: atl1c
raisa@raisa-dynabook-T451-35DW:~/Desktop$ sudo rfkill list
1: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
The card was working fine previously
