I’ve been trying to get my sound card to work using various suggestions from the forum but unlike others I think Zorin isn’t recognizing the driver (works fine in win 11).
I did a change to the grub to make it primary but the fixes in a related Ubuntu article all assumed the driver was not n/a.
I t think I saw a post which I now can’t find about downloading a slightly older driver but I don’t know where or how. The intel website wants me to log in but I don’t have an account.
To know more about Your Sound Card could You type in the Terminal sudo lshw -C multimedia and post the Output here? The Output show in Detail what Hardware You have.
Okay, if not already tried, install Pulse Audio Volume Control with the Command sudo apt install pavucontrol and then open it and choose there on the Output Tab Your Sound.
I'd already installed pulse audio. I tried the two commands and the second came up with a Daemon failure. I also tried force restartinf also as suggested in the article you linked.
I actually had already gone through that article but apart from the early stuff about inxi most semed to assume there was a driver.
I'm thinking I probably need to download a new driver which I;m not quite sure how to do. I did try installing sof-whatever but it made no difference.
It says it install missing destination file operand after Linux-generic-6.12
Not sure what it’s looking for. I did mainline 6.12.48 (the highest 6.12 in the mainline list) then got to Aravisians tuxinvader instructions and got this message. Maybe I can just ignore?
As noted in reply to @Ponce-De-Leon I did the highest version of 6.12 but got an error message and still no sound card. Thinking perhaps to try the highest number from main line which is 6.18 so as to overwrite the error and perhaps get sound function.
Is there a downside?
I have to go out but will resume in a couple of hours.
This sound thing is my last real problem before I can use Zorin for most things.
There is aemaining irritation about having to put in key ring and authentication passwords each time but that’s minor and I’ll worry about it after I get sound.
