Sadly, that Classic Menu has been deprecated and is no longer available.
But you have the right idea- sometimes installing a different menu can solve problems.
On XFCE, I use Whiskermenu in addition to the Zorin Menu.
On Cinnamon on Zorin, I use Cinnamenu on one monitor and Stark Menu on the other.
Hi all, I'm back, family issue is dealt with
So, thank you for all the replies & help
I'm running Zorin 15.3 Core version, the menu system is Gnome and not XFCE so it looks like cascading menus aren't going to be possible for me without a heroic effort that I really don't want to make
I think we can regard this as closed
sudo apt install xfce4
sudo apt install xfce4-whiskermenu-plugin
That is all that is required for the above... However, you may want to make other configurations once installed. So, that is an option - or it can be left as is.
If you like your post above can be marked as solution if you decide to leave it as it is.
