I think with Kubuntu 18.04 you could press a hot key ( ctrl I think it was for me ) and it would flash circles around where the mouse pointer was located on the screen. In some lighting sometimes the mouse pointer can be hard to see. Does Zorin have anything like this?
Zorin OS Core
gsettings set org.gnome.settings-daemon.peripherals.mouse locate-pointer true
I do not know of anything that would do so in Zorin OS Lite (XFCE) but Compiz has it contained within.
So does Cairo Dock, for that matter.
Edit: just found this:
https://forums.linuxmint.com/viewtopic.php?t=290409
Yad looked like it was going to be a tough install.
The compiz solution worked. Thanks
