You might be able to "downgrade" your firmware version for that laptop to get everything working (done some of it may have met EOL... but this could be problematic. Are there specific devices that aren't working that you would like to get working?
As far as I know, everything is working in ZorinOS 16 Lite on my Laptop...
Thanks for your advice...
But yeah Bluetooth doesn't work in any other Linux Distributions which I have tried except ZorinOS Lite and Linux Mint....
Write lspci and lsusb in terminal and post the outputs here. We are going to try to make it to work
surya0705@Surya0705:~$ lspci
00:00.0 Host bridge: Intel Corporation Core Processor DRAM Controller (rev 12)
00:02.0 VGA compatible controller: Intel Corporation Core Processor Integrated Graphics Controller (rev 12)
00:16.0 Communication controller: Intel Corporation 5 Series/3400 Series Chipset HECI Controller (rev 06)
00:1a.0 USB controller: Intel Corporation 5 Series/3400 Series Chipset USB2 Enhanced Host Controller (rev 06)
00:1b.0 Audio device: Intel Corporation 5 Series/3400 Series Chipset High Definition Audio (rev 06)
00:1c.0 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 1 (rev 06)
00:1c.1 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 2 (rev 06)
00:1c.2 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 3 (rev 06)
00:1c.4 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 5 (rev 06)
00:1d.0 USB controller: Intel Corporation 5 Series/3400 Series Chipset USB2 Enhanced Host Controller (rev 06)
00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev a6)
00:1f.0 ISA bridge: Intel Corporation HM57 Chipset LPC Interface Controller (rev 06)
00:1f.2 SATA controller: Intel Corporation 5 Series/3400 Series Chipset 6 port SATA AHCI Controller (rev 06)
00:1f.3 SMBus: Intel Corporation 5 Series/3400 Series Chipset SMBus Controller (rev 06)
00:1f.6 Signal processing controller: Intel Corporation 5 Series/3400 Series Chipset Thermal Subsystem (rev 06)
12:00.0 Network controller: Broadcom Inc. and subsidiaries BCM43224 802.11a/b/g/n (rev 01)
13:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 03)
ff:00.0 Host bridge: Intel Corporation Core Processor QuickPath Architecture Generic Non-core Registers (rev 02)
ff:00.1 Host bridge: Intel Corporation Core Processor QuickPath Architecture System Address Decoder (rev 02)
ff:02.0 Host bridge: Intel Corporation Core Processor QPI Link 0 (rev 02)
ff:02.1 Host bridge: Intel Corporation 1st Generation Core i3/5/7 Processor QPI Physical 0 (rev 02)
ff:02.2 Host bridge: Intel Corporation 1st Generation Core i3/5/7 Processor Reserved (rev 02)
ff:02.3 Host bridge: Intel Corporation 1st Generation Core i3/5/7 Processor Reserved (rev 02)
surya0705@Surya0705:~$ lsusb
Bus 002 Device 002: ID 8087:0020 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 005: ID 0c45:6481 Microdia
Bus 001 Device 004: ID 0bda:0138 Realtek Semiconductor Corp. RTS5138 Card Reader Controller
Bus 001 Device 008: ID 413c:8160 Dell Computer Corp. Wireless 365 Bluetooth
Bus 001 Device 007: ID 413c:8162 Dell Computer Corp. Integrated Touchpad [Synaptics]
Bus 001 Device 006: ID 413c:8161 Dell Computer Corp. Integrated Keyboard
Bus 001 Device 003: ID 0a5c:4500 Broadcom Corp. BCM2046B1 USB 2.0 Hub (part of BCM2046 Bluetooth)
Bus 001 Device 002: ID 8087:0020 Intel Corp. Integrated Rate Matching Hub
Here's a ScreenShot also regarding the same:
your desktop is looking awesome!!
you are sending result of zorin os lite.
Surya0705, You need to send the lspci result of the distribution which has this problem.
Well I just have ZorinOS and Windows10 Dual-Booted on my Laptop...But I can Live Boot in any Distribution. So let me just share the output from Ubuntu...I hope the Results don't make much difference be it Live Environment or Installed...
The Result goes like:
ubuntu@ubuntu:~$ lspci
And here's the Screenshot also Regarding the same:
As for the problem, Bluetooth doesn't work in Ubuntu(or even other Distributions. It just worked in 1 or 2 out of all the distributions I tested).
And for the Compliment regarding my ZorinOS-Lite Desktop... Thanks a Lot @ThDevloper
Sorry for delay. sorry i forgot to mention another command in the above reply. you have to send also the result of
lsusb
and
lspci | grep Network
and
lshw -class network
in Ubuntu
i just actually remembered that when i was a beginner in Linux i have also faced this Bluetooth problem and now i remembered how i solved that problem that time.(fact about me- actually now also i am a beginner
that time i have used the below commands
step 1 Run sudo rmmod btusb in terminal
step 2 Run sudo modprobe btusb in terminal
try to run the above commands in terminal and see if the problem solved in Ubuntu. if still not solved then give the result of above commands and i will manually try to solve this problem.
Here's the output for all those commands in Ubuntu.
ubuntu@ubuntu:~$ sudo lsusb
Bus 002 Device 003: ID 0781:55a9 SanDisk Corp.
ubuntu@ubuntu:~$ sudo lspci | grep Network
ubuntu@ubuntu:~$ sudo lshw -class network
*-network
product: BCM43224 802.11a/b/g/n
vendor: Broadcom Inc. and subsidiaries
physical id: 0
bus info: pci@0000:12:00.0
logical name: wlp18s0
version: 01
serial: c4:46:19:60:0b:88
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
configuration: broadcast=yes driver=wl0 driverversion=6.30.223.271 (r587334) ip=192.168.120.22 latency=0 multicast=yes wireless=IEEE 802.11
resources: irq:17 memory:fbb00000-fbb03fff
*-network
product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
physical id: 0
bus info: pci@0000:13:00.0
logical name: enp19s0
version: 03
serial: a4:ba:db:d7:46:b4
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix vpd bus_master cap_list rom ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=5.8.0-43-generic firmware=rtl_nic/rtl8168d-2.fw latency=0 link=no multicast=yes port=MII
resources: irq:18 ioport:e000(size=256) memory:d0b04000-d0b04fff memory:d0b00000-d0b03fff memory:fba00000-fba1ffff
And here is Screenshot regarding the Same:
What a coincidence...You remembered something and even I remembered something...
When I first Installed ZorinOS-Lite, there was a Popup which told to install additional drivers. Although Bluetooth worked out of the Box, I still installed the driver which was listed. I thought, why not try same thing in Ubuntu...
Opened that same application and after installing the following driver:
It worked...
So all in all, I think the Problem is now solved...
yes, it solved.
The problem with current releases of GNU/Linux is that they are geared to new hardware. The ethos of GNU/Linux had used to be "Breathing new life into old computers". You should really give Antix or MXLInux a try as they only uses 256 Mb RAM and is quick on older machines. I installed MX Linux on the machine my good lady uses which dates back to 2006 - An Athlon 64 with max of 2 Gb RAM and a 256 Mb AGP EVGA fanless Graphics Card!
Sure, I was thinking about trying MX Linux for a while now and will definitely look over to your suggestion
