Hi there,
My is there any way to collapse or manage the system tray in Zorin? I am using the GNOME-SHELL-like layout and I'm on 16.3 x86_64
See attached and thanks in advance!
Hi there,
By "collape or manage" what effect are you seeking?
I presume you are aware that Right Click on the Panel offers you some settings to customise your panel. Have you explored that.
Also look at Gnome Tweaks.
Im looking to hide those icons and ideally only have 1 icon that expands / shows all hidden tray icons.
Yes, im aware. .. however in the gnome-shell-like right clicking on that panel doesn't show any settings ![]()
Maybe KDocker or AllTray from Software Center.
hmm interesting.. i'll give them a try and report back...
Well, maybe one at a time, not both together, just to avoid conflicts between them and avoid ending up with more problems on top of the current one.
I tried both, AllTray didn't do anything so I uninstalled it. KDocker at least added the icon to the top bar but it was only hiding the software center, it may have trouble dealing with flatpacks. I went through the settings to see if I needed to change something but none of the options hid the icons ![]()
Is panel Intellihide what you are seeking. i.e. panel collapses / disapears under certain conditions?
If so, right click on panel, click Settings and find this:
I'd say no, on the first post JBlack shows that he wants to collapse only the tray icons that some applications display on the left of the system tray, Panel Intellihide is to adjust taskbar appearance and behavior, not the taskbar trays.
Install gnome tweaks:
sudo apt install gnome-tweaks
Install gnome shell integration for chrome/firefox from the extension store
Gnome-shell-integratie - Chrome Web Store
GNOME Shell integration – Get this Extension for 🦊 Firefox (en-US)
You can use this extension:
Tray Icons: Reloaded - GNOME Shell Extensions
Disable Zorin Appindicators in the extensions application.
Allright.. i tried this one
It seems skype is shown, a reminders clock showed up and no button to expand/collapse is visible.
In the extensions app, open the settings page (cog wheel) of the tray icons reloaded, change the tray icons limit to 1.
Huh, why my Extensions doesn't open? Seems broken, I have its icon but never opens the software
